Not having any luck with MikesXS, getting pretty frustrated with them now.
I wrote (several emails due to no reply) the following;
"The magura clutch perch.
The clutch cable (which I also ordered as part of the order) will NOT fit into to the clutch adjustment screw on the perch.
I checked my old cable and it won't fit either. The cables both (old and new) fit into the old perch adjustment screw perfectly. I can't use the stock adjustment screw in the magura perch as the screw is a bigger diameter and pitch. So have no other options. I did try and avoid hassling you guys but can't make it work.
My question is.
Is it the wrong clutch cable?
Is there something wrong with the perch adjustment screw?
Is there some type of adapter missing?
Think of it this way, grab a stock clutch cable, try to slide the end into a magura clutch perch adjustment screw. Just wont fit. :-(
Any help on these would be greatly appreciated!"
"Reply: Problem with order.
The Magura levers are not intended to replace the original lever and bracket, you may need to use a Yamaha adjuster."
Since I'm overseas. Everytime I get an answer that needs a return email I lose an entire day.
Amazing. I wrote the stock adjuster doesn't fit in the magura perch as the thread is the wrong size in my email!!!
So, does anyone know what the magura clutch adjustment bolt size/thread is. Ill go source a new one. Prefer to change that than have to wreck the cable to put on a smaller ferrule.
Cheers,
Peter
Posted via Mobile
