I meant to chime in on this thread earlier, but I had just received my cylinder bore gauge and had no idea how to zero it and use it.
I ordered a Dial Bore Gauge Combo (Model POW351075) from Summit Racing back in freakin' March. It was back-ordered for months and I got a direct shipment from the mfr. or likely the Distributor (Powerhouse Products) in mid-May. I paid $135 for it.
This combo set is actually labeled PHASE II on both the gauge handle and the dial indicator (900-098). I think its the same model Phase II handle & anvil portion as the one used in the YouTube video (by Jafromobile) referenced in this thread by DogBunny.
Jafro had swapped out his Phase II (900-096) Dial Indicator with a Cen Tech (Harbor Freight brand) Digital Indicator.
I like the Jafro's YouTube video below called Blueprint 101 - "Using Micrometers, Calipers & Bore Gauges".
http://www.youtube.com/watch?feature=player_detailpage&list=FLIsZyEuoH8DhIPjEKG7n36A&v=gjN0fGfUzl0
The Phase II Dial Indicator (900-098) that I got with my Set is incremeted in .0005" with every complete sweep of the needle being 0.05" or five hundredths of an inch. I found this dial indicator on a website and it listed for about $18. Pretty low-end... The Phase II (900-096) Dial Indicator used in the Blueprint 101 video was $42 on this same site. I like the fact that it is incremented in .0001" with every complete sweep of the needle being 0.01" (one hundredth of an inch). Will probably buy a Phase II 900-096 Dial Indicator and am considering an electronic digital indicator, cause, hey, I'm a Tool Junky too.
If I had to do it all over again, I'd buy the Phase II set that Jafro showed since it comes with the plastic case & 900-096 Dial Indicator. Not sure why I had to have the silly wooden case. Jafro's set is from Stef's B&B Fabrication Specialties. I found their website, but a price isn't listed. Search the site for "dial bore gauge". It's Part No. 40180.
Http://www.stefsperformance.net
A lot of the very same gauges get re-packaged by different companies, they put em' in different cases and charge widely variable prices for the same thing.
I had initially bought a single Mitutoyo Telescoping Gauge that covered a range from 2.125" to 3.5". I took dozens of cylinder bore measurements with this transfer gauge and flat gave up as I could not get reproducible measurements. Obviously, one must develop a feel for properly using "snap gauges". I'm sold on cylinder bore gauges, but setting them up & zeroing them is somewhat tedious.
For comparison, I took 12 total measurements of my 2 bores at 3 different depths and vertically and horizontally using my dial bore gauge and the Mit. Telescoping Gauge:
Phase II Dial Bore Gauge (RANGE of 12 measurements): 2.9532" - 2.9542"
Mitutoyo Telescoping Gauge (RANGE of 12 measurements): 2.9409" - 2.9754"
Though I thought that I was taking painstaking measurements with the snap gauge, I clearly was all over the damn place and sadly have to admit that I was stone-cold sober. Might as well had been 3 sheets to the wind. Oh, one's skills at using and reading an outside micrometer can introduce error, but I blame it on the transfer gauge moreso.
As 5twins mentioned, its pretty tricky to line up the digital (vernier) caliper edges with those little ball contacts on the dial bore gauge.
I much prefer to use a 2" - 3" Outside Micrometer (secured in a portable Drill Press Vise from Lowe's) to zero the cylinder bore gauge. I set up my gauge in a lab-type stand to hold it while I positioned the bore gauge arbor in between the micrometer's Carbide measuring faces.
As far as Digital Caliper recommendation, I love the first one I bought a couple of years ago and still use it. It's from Lowe's and its their Kobalt brand. You can toggle between metric and inches and you can Zero it with the push of a button. Cost about $30.00.
My Outside Micrometers (0"-1", 1"-2", 2"-3" and 3"-4") are all some label-less Chinese brand, but I've got standards and know to account for the slight inaccuracies (.0001" -.0002"). Jafro covers these well in the Blueprint 101 video.
