rich_mcd
My experience so far.
I bought an '80 xs last year, didnt do to much to it, this year I am trying to get it on the road. I have recently put the keihin carb kit on, with straight pipes and the bikes starts up and fires almost everytime with the first kick. The kick is pretty hard, so I assumed compression was pretty good.
The issue I have been having is the right cylinder seems to not be firing. This is what I am assuming due to my incredibly little amount of mechanical experience. The pipes shake, and push out air and get hot, but the plug seems to be wet with either oil or oil/gas possibly. I get a spark from both plugs, but I don't know what defines a "good spark" so I just assumed it was good enough, switched the wires to the plugs, little to no change.
Unfortunately, the bike got rained on last night, but it doesn't seem like any water got into the carbs just the outside of the pods are wet but now when it is running it pops blue smoke out the carbs.
I am going to do a compression test now, and adjust the cam tensioner but I was curious where the TCI is so I can disconnect it for doing the compression test. Also, how to I check the coils with a ohm meter, Like I said, I am an incredible newb!!
Rich
Rich
