azcafe
Hey All,
I can not seem to wrap my head around syncing my carbs using the dead cylinder method. Ihave a 1971 with pamco, HHB PMA, BS38 carbs off a 72. My intake boots do not have the barbs so I cant do the fluid sync. Also I have no rpm guage.
main jet is 135, pilot jet is 45, running pods and pretty much straight pipes. The pipes have muffles but they are pretty much asstetics only. Needle jet is stock and the eclip is on the middle slot.
Is there a video of someone doing a dead cylinder carb sync.
My understanding of it is you ground out one plug wire to the engine and run the bike on one cylinder. Then adjust the idle to where it will stay idel but almost to the point where it will cut out. once your at that point then you turn the air fuel screw and quarter turn each way. Which ever way it runs better then you turn the air fuel screw a eight in that direction.
The problem i am running into is in order for me to get the bike to stay at an idle speed on one cylinder i have to set it up pretty high so when I am finished with the syncing and both plug wires are hooked up the idle is extremeley high.
Any info would really help.
