kungfutoast
Hi Everyone,
I am hoping to throw this problem at all of you before I throw money at the bike. I am not able to get the bike to run...
Here is what I have;
* 82 xs650 stripped bare
* Uni pods on BS38, 135 main jet & 27.5 pilots. Float needle at the middle position.
* Hughs PMA and regulator
* Pamco Electric Ignition + e-advance
* Battery (standard issue solid state)
*emgo high output coil + lowbrow plug wires
* Headlight with no On/Off switch
* new piston rings and freshly lapped valve seats.
That's about it.
I checked for spark, left side is good, right side was a little weak. I definitely had fouled plugs. I was running rich with gas and not oil fouled. I had my jets turned way to far out @ 1 3/4 turns. Carbs have been synced and valves and cam chain are with in spec. I tested the coil and PMA and all check out within spec. I was having a charging problem when the bike was last running. Checked and rewired my grounds and went through the harness and found no issues. Bike hasn't started since. I did a leak down test yesterday and have no issues with leaks. I am not 180 out on the cam and have great compression.
I am going to start by getting new plug wires, rewire the bike once again and go from there...
But please share your thoughts,
That's about it.
