Hi all, I`m in the middle of rebuilding a 1977 model D. Now the wiring is a bit of a mystery. There are components on the bike that do not appear to be used like the light checker, reserve lighting unit, Diode,resistor and the brake lining switch. The question is do I need a diode and resistor, as the electrics seem to work ok without them.
According to the wiring diagram. The diode is connected between the brake lining light and the starter button/switch.
The resistor is between the flasher switch and the main headlight.
Now I know a diode only lets current through in one direction and a resistor reduces that current/voltage, but why are they needed here?
What is their purpose?
Any info to shine a light on this problem much appreciated.
chris r
chris r
