barelycompetent
81 XS650 Special
Hey all, I just read the tech section article on bleeding the front brakes, and that was an excellent article and well written, makes me feel somewhat competent to tackle that problem. I have to replace the upper brake line as mine sprung a leak on me. I want to just go ahead and drain out all of the old fluid and start fresh when my replacement parts come in, but the article never mentioned how to do that. Do I just put a tube on the bleeder nipple and crack it open and let it drain, or is there something else I have to do at the same time? Most of the fluid is out of the reservoir and and the upper line already. I was planning on just removing the bottom banjo bolt from the upper line and letting the remainder of the fluid drain out before replacing that part of the line, but that would leave fluid in the bottom brake line so there has to be a way to get that out first. The Haynes manual is not clear at all on how to do this. Any help, suggestions, tricks or advice is greatly appreciated. Once the old fluid is out, and the parts are in I plan on following the bleeder article in the tech section as I tackle that problem. Thanks all.
