Punkskalar
Hugh's HandBuilt
Perfect for mounting fenders, tanks, brackets and anything else you can think of on your custom build. Doing it right just got easier. No longer will you need to drill through your frame and use too long of a bolt and sacrifice strength to mount a tank/fender. These DIY Weld In Bungs are so simple to use. Just locate where you want the bolt, drill a 1/2″ hole, drop the bung into the 1/2″ hole and weld it up. It doesn’t get much easier or more professional than that.
These bungs allow for 1/8″ clearance to the mounting surface as well, keeping your paint fresh, and allowing room for Cables, Zip Ties, Isolation Padding, etc… under your tank/fender
*don't mind the bad grinding work on the frame, this was just for reference on a scrap frame.
Made From USA Manufactured 1018 Steel, internally threaded and sold in pairs (2 Count)
Buy a handful, you’ll be surprised just how useful these things are in your custom build.
Available in Both Metric and Standard Sizes (M8x1.25 or 5/16-18)
Available at www.hughshandbuilt.com in our shop.
Thanks for all your support folks!
