smiles79
Ok. 1975 XS650, pods, free-er exhaust, pamco, clubmans, brat seat, shock extensions, blah blah blah.
First, the electrical issue. It is intermittent, but sometimes I have no turn signals (front led, rear incandescent, aftermarket flasher), horn, or brake light. Not sure about the tail light, I think that filament is just blown. Sometimes they all work. Never have a problem with the headlight, starter, or ignition. Ideas?
Rear end issue: There is an intermittent scraping noise (kinda sounds like the sound your breaks make when they need to be replaced), but it will happen when I'm not braking, and stops when I swerve to the right (continues when I swerve to the left). I'm not overly familiar with drum brakes, do they make a noise like this when they need to be replaced? Ideas?
Lastly, my engine is making a noise. Sounds like it could possibly be a pre-detonation nosie? Kind of a pingy noise (man this is hard to explain). I'm probably not running very good gas, and I think the compression is higher than stock. This one I'm kinda just wondering if there are any common issues that should be checked.
Thank you for taking the time to look at my plethora of issues,
Smiles
Smiles
