1. Having trouble logging in? Try closing your browser and re-opening it. If that doesn't work, try a different browser or device. The site will be updated soon to resolve these browser issues.
    Dismiss Notice
  2. Dismiss Notice
Electrical Diagram Help - Minimal Push Start Diagram
Discussion in 'The Garage' started by Surfrat28, May 7, 2018.
  1. Surfrat28
    Surfrat28 XS650 Enthusiast
    Hey I am completing my 80 XS650 and I am adding a small push start button to the mix. My bike is bored out to the 707cc kit and I have had it kick back too many times for me to continue. Already have a bad leg and do not want to risk making it worse. I have modified a diagram that I have found and wanted the groups opinion before I cut all my wires and try to run it this way. Please I mean no offense to the original person that made this electrical diagram I am using the set up that I currently have on my XS650.
  2. Typically the solenoid ground wire is switched. Run the power to the solenoid. Run the ground wire to the switch and from the switch to ground.
    Jim likes this.
  3. You can do it either way. If you are using stock handle bar switch then you use the ground from the solenoid but if you are putting in your own two pin push switch then you can break the positive (12 volts) wire and that will work also. I have done it both ways many times and have even used a key car switch to start bike. If you are still stuck contact me at DADDYGCYCLES@YAHOO.COM and we can talk on phone if you need that.
    RICH
  4. Surfrat28
    Thank you for the tip.
  5. Surfrat28
    Thank you! I appreciate the help! I am installing a mini switch button and one on/off switch and kill switch. If I run into anything ill contact you!
  6. Surfrat28
    Not sure if this will work but thank you for everyone that helped with the advise on the wiring diagram!!
    TwoManyXS1Bs likes this.
Share This Page
