Capt_Zoom
Raider Rider/xs newbie
Can anyone answer or confirm my questions/thoughts below:
I'm building a brat for my wife, 1980 S model, retaining the starter, using LED rear signals/tail and probably regular front turn sigs. Switches will include key, Kill switch, hi/low, signal, horn, start
Electrical components:
6- Relay assembly (starter I think), I can skip this is wife is smart enough not to hold the starter button too long right?
13- Flasher relay - will this work with LED (will they only blink fast...that's ok with me)
22. -Flasher canceller unit...how does this work? Do you need to use the stock flasher handlebar control? Will it work with LED? I can skip this right?
23- Light checker (Headlight correct?) I can skip this as well right?
24- Reserve Lighting unit - I can chuck this correct?
So if i'm understanding things correctly I can basically get away with only using the following:
-Starter Solonoid/Relay (forgoing the starter safety relay)
-Flasher relay (#13)
-Electronic Ignition module
-Chrysler Reg/rec setup
-Stock charging setup (less reg/rec
-Coil
-Battery
Is this correct? Thanks.
-Coil
-Battery
