Bjorn
Do you guys have any idea where to look next
I then measured from the red primary winding at the coil to ground (with the entire wireloom intact) and it gave me similar values as after the test ride. Around 7 ohm.
Based on those two statement, you have a bad coil. Should read about 4ohms between the two wires.... and open on either wire to ground...case...earth... whatever you want to call it.Just a update about this: I just unplugged the orange and red wire to the coil, now there is no circuit between red-ground and Orange-Ground.
Yeah... my bad. I was indeed lookin' at the points section.You have a T.C.I. electronic ignition and it requires a lower ohm coil.
