#18 looks like what you want and is in stock. If not, the part numbers are broken down into 3 parts 99999-06012-00 is an example. The second part, which is 06012 tells you the size. That bolt is 6mm in diameter and 12mm in length. If the second part was 08024 the bolt would be 8mm in diameter and 24mm in length. The first part of the part number tell what type of part it is such as bolt, screw, washer etc. and last 2 digits generally determines the finish such as black, cad, etc.
Good info, but he needs 17 and 22. 22 is available, but 17 isn't. That link is weird. It has multiple part numbers for many items, calling them bolts in one part number, and nuts in the other. Here's the right parts drawing for his year: http://www.boats.net/parts/search/Yamaha/Motorcycle/1975/XS650B/FRAME TX650A - XS650B - C/parts.html
It make more sense.
Anyways, he already contacted me, l have the bolts he needs, and I PM'd him.
