DanielBlack
XS650 Junkie
Mailman and I met up for the second time this morning and once again he commented on the bassy, throaty sound of Stella's exhaust. Both of us ride 1977D survivors in pretty good shape other than a 40yo worn engine. Stock exhaust, OEM-style K&N air filters in the stock air box. The difference in our exhaust sounds was a bit of a mystery.
Well, not for long. Later in the day, Detective Mailman sent me the following text and picture.
I was thinking about the difference in our exhaust sound and I remembered an old trick that guys sometimes do. They either go into the end of their muffler with a very long drill bit or hole saw or they take a 4' rebar and grind a chisel end on it and knock or drill holes in the baffles of their muffler.
7 inches in from the end of your muffler there is a solid blocked off baffle. The exhaust passes through the drilled holes internally. If you look into the end of your muffler with a good flashlight I'll bet it has holes drilled in it or it has been knocked out entirely. Here's a photo of what it should look like.
On his urging, I went spelunking and Mailman hit it right on the head. Here's Stella:
On another front, I've been slowly working on my jetting.
5twins suggested we both might like 1 or 2 up considering the K&N filters. Following his advice of starting stock and step by step increasing the main until the first sign of stumble, I'm now 3 up and no stumble.
I've been hesitant to go another, knowing that being so far out of the expected range might be a symptom of another problem.
Mailman's thought of open baffles lays my jetting worry to rest. Time for the next step up...
