TeeCat
One-Mik Wonder
Hi, friends.
Hey... TC is finally doing his valves!
The covers all came right off okay, and even the gaskets look good, so I might as well save my new ones.
'k, question:
IF I'm right at TDC on each cyl - I am using the method of feeling for slight (gawd, it's tiny!) play in both tappets on the same cyl - here's what I have:
- the left intake will take a .003 with very light drag
- the left exhaust will not take an .006... seems quite tight
- the right intake will take an .003 with loose drag, and an .004 is tight
- the right exhaust seems really tight.
Now, I'm ONLY going CCL to keep tension on the chain, but I'm still a little doubtful about being RIGHT AT TDC on the compression stroke. I know it can't be a very wide range, but I'm kind of concerned about doing the actual adjustment and possibly being ever so slightly in the wrong place on the cam. In any case, the tappet movement that I feel is so tiny, so is is safe to "feel" your way though this this way?
I can't really see the piston action in there, even with a light, and I'm reluctant to stick anything in there... I'm out of knitting needles...
So, TDC. What do you guys like to see/feel in terms of TDC before you make that adjustment? I'd hate to wind up with them too tight or too loose after this.
Off to get a 4mm or tiny adjustable wrench now... I only have down to 6.
Thanks!
TC
'k, question:
Thanks!
TC
