intake goes down, comes back up then another 1/2 turn of the crank is the tdc you want.
You are at TDC AFTER the compression stroke.
I'll check it'll take a few minutes I haven't removed the covers yetCheck, are the other cylinder valves loose now?
Don't worry about "barely" closed. Once it's "fully closed" you still have about 120-130° of rotation to go yet.All valves are rock solid after rotating ccw wait till intake barely starts to close line up marks no slop at all neither intake or exhaust
Yep no insult takenDon't mean to insult you Mikey, so don't take offense....
Intake valve is the one in back by the carbs.
Ccw means hold the wrench high and push (pull) it forward towards the front wheel and down.
We on the same page?
Let me try thatDon't worry about "barely" closed. Once it's "fully closed" you still have about 120-130° of rotation to go yet.
The idea is to make sure the intake is the valve operating and then rotate to TDC from there.
Okay I couldn't leave without at least trying the exhaust valve. Good to go at 012WTF now it seems back to where it should be plenty of room for adjustment
I've got to go for now
I appreciate you guys sticking with me
I'll report back tomorrow
Thanks!!!
I mean 006Okay I couldn't leave without at least trying the exhaust valve. Good to go at 012
I gotta quit the intake is at 006 like it should be.I mean 006
Sorry
Tomorrow exhaust at 012 and then to the left side
I confuse myself lol
So you saying that this 73 will be at 003 and 006
Strange on my phone I can't seem to correct my postSo you saying that this 73 will be at 003 and 006
I guess I had to look at the service bulletin date and yep it's from 72
Aren't the newer bikes at .004 .006 exhaust
Why the difference I thought the older bikes had a larger exhaust clearance
Suppose they re thought the spec's
Nevermind found the change option next to the report buttonStrange on my phone I can't seem to correct my post
