It only takes a couple minutes to mark the pointer on the rotor. In the time it takes you to hunt down a key and modify it you could have marked and remarked the rotor 50 times. This alternator is so reliable that you will likely never need to remove the rotor again for as long as you own the bike. You certainly won't be removing it often enough to make the effort of fabricating a key worthwhile.
