firing on one cylinder ,new ignition
josh...,
Well, then you have the factory TCI which fires both spark plugs at the same time from the same coil so it is very unusual to only have spark on one cylinder. How did you determine that you only had spark on one cylinder?
josh...,
I have spark in both cylinders. Compression is 125psi each, all valves work properly. I've swithcthed the plugs and plug wires to the opposite sides and it's always the same outcome dead right side running left.. If I put fuel directly into the motor on the right side it still won't fire.. It starts to pop the right side about 4000-5000rpm then it back fires like crazy.
