Hey all,
I acquired an 82 Special to build into a custom. Old owner had it sitting for 2 summers unused but said it ran great before that. Carbs were gummed up when I got it; wouldn't start.
I put new mufflers on it, Emgo turn out style, very free flowing compare to original; almost straight pipes but not quite. Also installed UNI foam pod filters. Cleaned carbs, replaced all carb gaskets, freed up the stuck float needle, everything inside carbs looks nice and clean now.
The bike started last night on the first kick. I was thrilled. However, it is running poorly. it starts extremely easily, but it will not idle. I have to keep it throttled up or it dies immediately. It's backfiring a little, subtle and infrequent but noticeable. timing sounds a little bit screwy, it just doesnt sound like it's firing quite right.
tonight I'm gonna look at the following:
new spark plugs
valve adjustment
cam tensioning
Checking points gap
looking for other advice. What else could I look at to sort her out? I was also thinking idle mixture adjustment. I don't know much about adjusting timing. Any advice or links to guides or videos would be amazing.
I expected it to be a little bit cranky after increase exhaust flow, and increased air with the pods so I'm not surprised that she's acting up. Im hoping i wont have to re-jet the carbs, but thats in my mind as well. Just looking for some advice. I'm not an experienced bike builder. Thanks for any help everyone!
new spark plugs
valve adjustment
cam tensioning
Checking points gap
