robotoe
das boob
Hello,
Selling parts I've been accumulating since upgrading or stripping down depending on where you're looking. Up for grabs:
left-side vacuum operated petcock - $10.00, could use a rebuild kit, PO only ran in it on "prime", I did as well for a few days till I ditched it for a non-vacuum.
carb clamps & flanges - $5.00, the boots are shot, but the metal flanges and clamps are still in good shape.
Charging system:
rotor - $25.00, in good shape, ohms checked
rotor puller tool - $10.00, same one off mikesxs, don't need it anymore
stator w/good brushes & complete wiring - $50.00, brushes have plenty of life left, might need to replace bolting hardware but you can decide
reg/rec - $25.00, in good shape
COMPLETE SYSTEM - $100.00
coil - $10.00, one boot has a crack on the rubber, doesn't affect performance
side covers w/badges - $25.00, plastic, good shape, L side cover has small crack at top and bottom nipple could probably be re-fortified, both covers secure to frame fine though
front fender w/cable loop - $25.00, pretty sure it's OEM, PO painted it black, I began sanding to repaint later, decided to pull it anyway. Superficial rust underneath. Small dent from headlight housing on top.
bootleg speedo w/used cable - $15.00, you're really buying the cable, but the speedo is a tinkerer's dream!!! (Ok, i'll admit, it's mostly useless, but not quite fubar). Backlight doesn't work, bulb is probably burned out, the needle has fallen off, but still registers speed with remaining indicator. Will include mounting portion in photo.
Pricing firm. PM or reply to thread. Shipping out of Austin.
Safe & happy riding!
-rtl
Charging system:
-rtl
