Fork tube reassembly
Doctari
I bought a bike in a box and I am reassembling the fork tubes. The allen bolt that goes into the bottom of the fork does not have an o-ring. The repair manual that I purchased shows "packing" between the bolt and the bottom of the fork leg. Could I just use an oil resistant o-ring or do I need to special order some kind of "packing" from Yamaha?? Thanks
That is at the top of the fork, I am talking about the very bottom of the fork. It is between the allen bolt and the bottom of the fork.
On my 80 it's a copper washer. What year forks do you have?
From here. You could prolly find one at a hardware store.
Yes. Gasket... washer.... all the same.
The factory also called for some thread locking compound and some gasket sealer on the threads .....
Personally, I don't bother with the thread locking compound but I do apply some Yamabond (or Hondabond) up at the top near the bolt head .....
FWIW, I just took mine apart and it was a red fiber washer (like some of the oil drain plug ones) not the copper I was expecting. I'm sure it's not available anymore and if I had to replace I would use copper.
I would definitely use (annealed) copper washers. Some may like bonded seals ("Dowty rings") for sealing bolts and plugs, but I don't. Soft aluminum washers may work just as good as copper.
