fresh rebuild, first start, advance mech destroyed?
Brew
as the title says. fresh rebuild first start. was sounding good and then it stopped. after some inspection I noticed this. The pin was in there and now it's nowhere to be found. Any ideas on what might cause this?
I found the pin and now it seems like the cam has moved in. When i put the pin in, it is hitting the inside of the bearing cover and it wasn't like that before i started it. What would cause the cam to move towards the ignition side? Now there is some chipping around the hole where the pin goes that was caused by this accident.
New theory. I might not have tightened that securing nut all the way down and the advance mech walked out enough that the pin broke it and also pushed the cam in which is why the pin is now on the inside of the bearing oil cover...
The cam can't move in if you properly seated the bearings all the way onto it at both ends. If you didn't seat the bearings in all the way then I guess something like this could happen.
the bearings were seated all the way on to the cam. I think the pin hitting the back side of that advance unit forced the cam in a little. I just tapped it with a hammer from the ignition side and it now sits correct. I probably have to re-seat those bearings on the ignition side. Is there a way to do it without removing the head cover? big socket maybe?
do any other bikes share the same unit? If im going to spend 70 on a new unit I might as well by the e-advancer that pamco sells.
Look at it this way....................this is actually a lucky day for you. The mechanical advance, while they worked quite well for the first 20 or 30 years, have now lost their precision and best to retire them to a museum. The pamco E-advance works extremely well and will be reliable....................a great addition to your bike.
You could try loosening the head nuts on the points side and driving the bearings in with a socket. Be aware that this is a very precise setting. You want the cam perfectly centered in the head so its sprocket aligns with the one on the crank below it. The bearings will be inset on both sides. Measure that inset and make sure its equal.
5twins,
So, there is nothing that holds the cam and bearings laterally?
The top cover clamps down on the bearings and holds them (and the cam). At first glance, this looks wrong because the inner bearing hangs off the casting a little, but its the way it has to be. The bearings need to pushed in as far as they'll go on the cam so it can't "float" left and right while spinning, throwing the sprocket alignment off. The bearings must be inset into the head to allow the points and advance housings to seat fully and seal. The housings have a step on the back that sits into the bearing inset .....
Thanks everyone for the info. I'll be ordering my pamco e-advance with the 60 rotor today! 5Twins Do you have a measurement for how much of that bearing race is showing?
Looks like 2-3mm...
Brew he stated That the bearings need to be pushed far as they can go on the cam. Then the cam is centered on the head. Good luck Tony C
With the head cover on and bearings seated all the way to the stops on the camshaft, the outer bearing races should be inset an equal distance on their journals. You can measure this with the depth gauge of a caliper.
I have had reports of the PAMCO plate protruding to the extent that the components make contact with the magnetic rotor. This is caused by a too thick gasket for the points and advancer housings which would then leave the cam and bearings with no actual limit to their lateral movement and be dependant entirely on the proper placement of the cam and bearings upon installation. So, if the gaskets are too thick, can the cam and bearings move laterally? Or are the housings supposed to contact the cam bearings?
Once the top cover is installed and tightened down, the cam and bearings shouldn't move side to side, even if there is a little space between the housings and the bearings. I've never checked whether the housings actually touch the bearings, but I'm going to. I want to find out if I can drive the housing seals in a bit further, so they protrude out the back of the housing slightly and don't hit the bearings. The ends of the cam don't stick out through the seals very much at all so setting them in further may help them seal better. In particular, this can be a problem with the MikesXS "improved" triple lip seals. The added lips are on top, towards the outer side of the seal, and sometimes don't even get bearing on the cam. That makes these replacements more prone to leaking than originals.
