Its been a little while for an update, and I am almost done with all the fab work. Tank and fender are with Visual Impact getting painted. Ill be stripping and painting everything else myself to same some money.
The stock adjusters are too short for a Ardcore tail, so I lengthened them. I didn't like the adjusters that came with the tail because they were std thread and required spacers to be made. Not to mention, they did nothing to address the inside spacing since the axle plates are only 3/8" thick. The stock adjusters are a slightly larger diameter than the 3/4" washers, so the face of the bolt rides in the slot. Works pretty well and its even on each side so I can measure the bolt to ensure the wheel is straight.
Well I hated how long and obnoxious the adjusters looked, so I spent a few days thinking and went back to the regular front bolt style adjusters. I cut the end off of the stock adjusters and welded a 3/4" washer on each and then grind each down.
I had to redo the license plate bracket as well. The mount for my light had broken off already, and upon closer inspection the actual license bracket was cracking about the mounts. I tried locating some 1/8" plate to build it out of to no avail, so I did the next best thing and welded 2 16ga plates together. I got stupid though and once welded curved it instead of bending it 90* for the mounts. If I could have done it again, I would of simply welded on some 1/8" tabs onto the curved plate bracket. This will be something I rebuild down the road to save some weight and make something that looks better.
Something else I am working on is finding all brass and copper lights to clean up, refurbish and sale. The taillight is all brass with a glass lens. I haven't made up my mind on the headlight yet. I will likely stick with brass, although I have two copper lights with amber lens.
Redid the seat mount, although it looks almost identical to the previous one. I had to include a rear brace as the previous one was just flat 1/4" welded to the backbone and it was bending.
I wanted to make a brake brace a little different, however I didn't have square stock. So I went with flat bar and twisted it. Thought it looked alright, but I was a little worried about the strength so I went back to a standard tube.
