Is there a part number for the o-ring between the plastic reservoir and the metal body on 1977 and later front brake master cylinders?
Is there a part number for the plastic reservoir?
Hey man, how's the old hood? I would clean everything well with non-chlorinated brake cleaner, incl. the o-ring, then give the o-ring a hefty coat of something like Permatex Motoseal or Yamabond and reassemble. While the reservoir is off it would be interesting to see if it could be buffed to be more clear. Cheap paint swirl remover might be a good last pass; a friend uses it to buff headlights to new-looking. Must keep the buffing pads separated...or a way to make a leaking reservoir stop leaking....
I take it campfires are allowed in Texas nowexcellent resistance to hydraulic oils. Does brake fluid count?
... What I don't know is how much "squish" there is supposed to be...
...TwoMany, that is a cool DIY o-ring kit. I never would have imagined it. Have you used it? Maybe that's an old pic from when you got it, but hadn't used it yet?
