SCARE
Scareous XS650
Howdy, so my new XS650 Special is great, I just took it for a Warrant Of Fitness test (here in New Zealand) to get it roadworthy.
It failed on one thing (I'm happy with that), as it has been off the road for years.
The taillight/headlight doesn't go. They were going, until I jiggled the front brake switch in order to get the non-working brake light to work. Now the brake light works and others don't!
Obviously, as you can tell by the photos below, it is more than likely due to the corrosion all around and under the front brake master cylinder!
My question is which parts on mikesxs (or somewhere else) will be the best replacement for my setup, and ease of swap-over.
They all look slightly different. I am running dual front discs.
So, new master cylinder, brake switch, switch assembly, and lever. I want to replace the lot. Any help with pointing me in the correct direction would be appreciated.
My frame number is 447-910-658, and it is a XS650 Special, like I said with dual front discs.
Thanks!
