1. Dismiss Notice
    Dismiss Notice
Front wheel 72 XS2
Discussion in 'The Garage' started by prue1, Dec 31, 2019.
  1. prue1
    prue1 XS650 Enthusiast
    I'll try this again, If I tighten my front axle I get a very noticeable clicking noise and my speedo hub wants to move with the wheel. If I loosen the axle the noise goes away for the most part, but my speedo hub still wants to move with the hub, although not as quickly. I believe I have all the bits in the correct places. Does anyone know the correct length of the internal hub spacer? I think it may have been shortened by a previous owner, causing the axle to seize as it is tightened? Any thoughts on this or other ideas would be greatly appreciated.
    Happy New Year
  2. GLJ
    GLJ Never go faster than your guardian angle can fly. Top Contributor
    I measured a spare and I get 45mm. The part of the speedo drive the axle goes through measured 23mm. I'm not a machinist so the measurements could be off a hair. If you put the speedo drive in the hub you should be able to press in on it and be able to rotate it with no binding.
    A few pics of a spare hub.
    Mailman likes this.
  3. prue1
    My spacer measures 43mm. You wouldn't want to sell me your spare would you? Thanks.
  4. GLJ
    Let me think about it.
  5. GLJ
  6. prue1
    Thanks GLJ, I'll check that out. Have a great new years eve!
    Mailman and gggGary like this.
  7. prue1
  8. GLJ
    I'm out of town on business right now. When I get home at the end of next week I'll PM you. I think I can help you out.
  9. prue1
    I look forward to your message, thanks. In the mean time I will do some searching.
  10. gggGary
    Turn down the one you got from partzilla? Anyone with a metal lathe could do it. Hint take the along the wheel/hub, length is critical. In your want ad emphasize that it MUST be from a 72 or you will just get another "wrong length" part.
  11. prue1
    Thanks.
    gggGary likes this.
  12. GLJ
    prue1
    I don't normally sell parts. In your case I'll make an exception. I'll PM you with price.
    GLJ
Share This Page
