Gas Tank ID
Triangleforge
Seemed like a good idea
Prescott, Arizona
Can anyone ID this gas tank? The front mounts fit the XS650 frame, though the tank is shorter than the Special tanks on my '78 & '80.
Photo of the bottom:
Since I'm aiming in a Scrambler/Tracker direction with the '78, this would be a good piece to the puzzle.
Thanks for the lead - looks like the Sudco catalog lists tank badges for the DT1 .... and they're the same PN as they have for XS650 badges; the oval ones at least.
That makes me happy.
It fits the front mounts?
Is the tunnel wide enough?
Could you get some pictures of it on?
So many questions..i love dt tanks so much!
It does fit the front mounts (with the rubber bumpers on the tank) when I went to check it on the 1980 XS650 frame. It appears that the tunnel is wide enough, but it's quite a bit narrower than the Special tank, and doesn't really clear the bulky twin wiring harnesses that run along the backbone. I did a little fiddling and am pretty sure it will go on with some very minor mods, including slimming down/re-routing the wiring harness and fabbing a rear pad & back latch of some sort.
I'll play with it a bit more later this week & take pictures.
Sweet..
I dont run much wiring so Id imagine id be good on that aspect If i can find one..
