thunderdork
Hi,
I have a '78 standard that I was gonna redo the wiring on. So I decided to go ahead and break it all down for powder coating/paint/polish. I was wondering if you guys had any advice on the following questions.
Generally, what's good all around advice for any gotchas you guys have run into?
Anywasy to make stripping paint easier other than Airplane stripper and a wire/sanding wheel (don't have big enough blasting cabinet)?
I know I'm gonna go through and replace all the bearings and bushings while I'm in there. Any other parts I should go ahead and swap?
Any specialized tools I should get such as mototcycle jack, impact sockets, etc?
Wasn't planning on redoing the engine since it has all its bits and good compression. Should I not do it to keep from getting overwhelmed or should I jump in and redo it at the same time?
Any organizing tips for keeping things in order? Baggies, boxes, chalk body outlines on the floor?
Any guidance or advice for a first time restorer is greatly appreciated!
