Green coil placement
hank2
Reisterstown Maryland
Fishing for ideas. I am mounting the green coils with the Pamco 277 kit on a '79 special that is stock. Before I do a lot of trial and errors, any tips? Thanks!
.......................hi i put my coil from a14- 0901 pamco up in front of the tank on the little bar where your horn would be,, then i used 2 solid plastic tires and mounted the horn bracket nearly back where it was ,,but the coil fits there well ,and then run your wires under the tank ,without the tank being on ,,, and tire up those wires ,,mount the pamco and it all fits well regards oldbiker
Oldbiker, looks like a great idea for one coil but I'm running two. I'm sure if I look at it enough and with input from this site a good resting spot will present itself. Thanks and enjoy your winter Down Under!
