UncleBuck
I know I have to replace the LHS coil on my '78 Special, but I'm torn on if this is the right time to do the Pamco upgrade while I'm mucking about with the ignition. Cash being king, after all.
If I were to buy any of the high output coils from Mike's how stupid would I be to run it using the stock points?
Also, the LHS coil is cracked, the terminal for the plug wire is nasty with rust, and it gets hotter than all hell when I run the starter. It's clearly pooched. Is there anything I should check into that would fry one coil (but not the other) before I sink some cash into a new coil only to fry that in short order?
