1. Dismiss Notice
  2. Dismiss Notice
    Dismiss Notice
Grinding a carb slide cutaway...
Discussion in 'The Garage' started by LPYYZ, Apr 27, 2018.
  1. LPYYZ
    LPYYZ XS650 Enthusiast
    Would anyone have any tips on grinding/filing a carb slide cutaway?
    I had a 2.0 slide installed on my VM34’s but I was getting the black plugs after 50 mile problem. Throttle response was great though.
    I moved to a 2.5 slide to cure that problem but now my initial throttle response is poor due to the leanness.
    Ive heard of people going a 1/4 size up or down by filing the slide cutaway.
    Any tips or tricks would be appreciated...those slides aren’t cheap.
    Thanks in advance,
    Liam
    gggGary likes this.
  2. gggGary
    gggGary Stop that! Top Contributor XS650.com Supporter
    Following, :popcorn: Those slides are anodized. Would require some fixturing to get hold the right angle I suppose a real careful guy could mark the desired line with a sharpie and work to it on a sheet of sandpaper on a flat surface. So would you remove a pie shaped slice or would it be thin flat section that needs to go?
    Jim likes this.
  3. XSLeo
    Wouldn't it be easier to put in a bit bigger idle jet? Possibly a richer needle?
    Jim likes this.
  4. 5twins
    17,134
    6,364
    688
    I think where you sand/file would depend on what you're trying to do to that particular slide, make the cut-away taller or shorter. I'm pretty sure the 2.0 and 2.5 numbers refer to the height of the cut-away. To make a 2.5 into the "modded" 2.25, you would have to sand/file the flat bottom. To make a 2.0 into the "modded" 2.25, you would have to sand/file the angled cut-away.
  5. LPYYZ
    The number does refer to the size of the cutaway. A 2.5 slide is leaner than a 2.0 slide because it has a larger cutaway.
    From what I understand I would have to file approximately .010” off of a 2.0 slide to turn it into a 2.25 slide.
    I’m just trying to find a way to file both slides accurately so they are symetrical and retain their cutaway shape etc.
    I don’t think I trust myself to do it with a hand file and set of calipers but right now I don’t see any other option.
  6. LPYYZ
    Unfortunately changing the pilot jet or needle won’t have much effect on the 1/4 throttle open fuel/air ratio. It’s mostly slide cutaway at that point and that’s where I seem to spend most of my time cruising around.
  7. 5twins
    17,134
    6,364
    688
    I think it would be easier to file/sand the flat bottom of the 2.5 than sanding the angled cut-away on a 2.0. Easier to do more accurately too.
  8. Jim
    Jim The thrill of victory and da agony of da feet. Top Contributor XS650.com Supporter
    Got a friend with a lathe?
    Paul Sutton likes this.
  9. LPYYZ
    I don’t think sanding the flat top of the slide would have any effect as it’s the bottom cutaway bore that determines fuel/Air ratio.
  10. LPYYZ
    I might be able to find someone with a lathe...thanks for the idea.
    Jim likes this.
  11. 5twins
    17,134
    6,364
    688
    No, not the flat top, the flat section on the bottom.
  12. LPYYZ
    Ahhhhh, I misunderstood.
    It would be worth a try before getting into the cutaway curve. Definitely easier.
  13. Jim
    And if you want to take down the cutaway..... find a fried with a lathe AND a mill... ;)
  14. 5twins
    17,134
    6,364
    688
    I just found this VM slide pic on eBay. The bottom isn't solid like on the CV slides, it's just a ring of metal around the outside. Still, I think working the flat bottom would be easier than the angled cut-away .....
    [​IMG]
    A piece of 320 or 400 taped to a flat surface like a plate of glass. Slide bottom worked against that in a circular or figure 8 pattern. Measure the total height first then sand a little, measure again, etc. From your research, it appears you don't have to remove very much.
  15. Signal
    Signal XS650 Junkie
    Watching with interest. I think 2M has posted about doing this.
    You have already worked out how much you need to remove.
    I read that the number is the height of the cutaway in fractions of an inch. However I cant remember what the fraction is I think it may be 32nds but will need to check.
  16. 5twins
    17,134
    6,364
    688
    At first I thought it may be metric but MM's would be too small and CM's way too big. Fractions of an inch make more sense but a 32nd would be too small. That's not even 1mm. Maybe it's eighths.
  17. 650Skull
    650Skull Dinosaur Lives Top Contributor
    Can't find it at the moment.............I have seen an article on a spacer, (for the want of a better word), that fills the bottom of those sliders because they reckoned the area that is recessed causes to much disruption to the airflow/mixture..................makes sense to me but what do i know..............
    Anyone heard or know about this???
  18. 650Skull
    Found it...........Could be a snake oil product.................
    any ideas on the theory and a practical application.........
    UFO Carb flow optimiser01.jpg UFO Carb flow optimiser03.jpg UFO Carb flow optimiser04.jpg
    gggGary likes this.
  19. Jim
    That would be my guess. Claims a 1-2 hp increase per 100cc's means 6-13 hp increase for our motors..... just by cleaning up the airflow under the slide..... sounds like a pipe dream to me.
  20. 650Skull
    Yes Jim the claims of all that horsepower could be the snake oil part ...............But......................what i am asking is the spacer going to make the fuel delivery more efficient due to less turbulence...........More than one part to that post............funny how people see what they want and not the content?????
Share This Page
