cros36
thread killer
allright here is a picture of my 'electrical bag' the problem with it is that i think the way that it is mounted makes it vibrate pretty bad. it will almost pop the fuses out and has killed a kill switch. i was at my friends house and we were looking at it and i was thinking about redoing the whole thought process on how its mounted when he said that i should try to rubber mount it first and it might help with it. the problem with that is all my grounds (besides battery) are routed into the bag.
my first thought was i cant do that because my grounds are in there and i would have to reroute my grounds which still wouldnt be much of a problem, just not something that i want to do because i like having them all in there and not attached to my frame somewhere outside of this bag and visible.
this is where my limited expertise comes into play....if i were to rubber mount it would the bolts going from the flat bar through the rubber mounts to the bag provide enough for the ground?
also i was thinking about possibly making a jumper wire that would go from the top down like this....
bolt head
jumper wire
flat bar
rubber
jumper wire
electrical bag
i hope that makes sense.
heres the pictures...
thanks in advance. i hope i explained myself correctly.
bolt head
jumper wire
flat bar
rubber
jumper wire
electrical bag
