Adrenaline-Junkie
Ive seen a few people do fork swaps but there hasnt been a lot of information posted on the details involved. What GSXR forks are most commonly used in the swap and what modifications are needed to do it? Thanks
So you just made plates to use with a stock wire wheel and the gsxr rotors? That would be ideal. How hard was that to do?
I measure just over center axle to top of triple. Haven't decided if I am running a dampened or not its def an option.
The rotor is stock xs and the exact same diameter as the gsxr rotor I have gsxr wheel with rotors too for another xs bobber project. And the xs rotor measures thick, thicker than the gsxr but shouldn't be too bad.
Got my wheel and stem bearings today and mocked it up need to cut the rotor spacers but looks like it will work just fine.
Stem bearings 48x30x12 cut the bottom bearing cup down to deep and it fits perfect with no mods to the gsxr triple.
Wheel bearings 47x25x12 center spacer brake side spacer speedo drive side spacer made from 1.25 Dom Molly tubing perfect inner and outer diameter.
