Gsxr fork swap
Jay5
Vancouver
Hey xs650,
question so I have everything together. I am using a cognitomoto stem pressed into the lower Gsxr tree. I had to use 2 spacer to clear the bottom tube. Now when I put the 2 spanner nuts on top there is a 2-3mm gap.
now here’s the question do I need to put another spacer on the lower tree ? I’ve contacted cognitomoto but with it being the holidays I’ll probably get a response sometime next week.
has anyone done this swap using cognitomoto stem and the stock trees ? I followed the instructions provided, just want to know if I did something wrong.
Not the style build I expected to see, but looks pretty good. I can’t help with your question; other than just reinforcing to relax. Cognito moto will get back with you they are a reliable company so you shouldn’t worry.
Not the style build I expected to see, but looks pretty good. I can’t help with your question; other than just reinforcing to relax. Cognito moto will get back with you they are a big company so you shouldn’t worry.
I am, just thought I’d ask the forum and yes I have search.
Maybe they sized it for tapered roller bearings? The top bearing sits a bit proud when using the tapered rollers.
