Gary, I decided to answer your PM on this thread, just to give people an idea of what could be done, if they were so inclined, with a prefabbed hardtail frame. Keep in mind, this is not necessarily the best way to do it, but it IS a way it could be done, as long as you make sure, beginning to end, that everything is square. This is of course meant to be done on a bench with the rear tire and motor removed...
It's definitely DOM tubing. I'm pretty sure that was a kit (tubing cut to the right lengths and pre-bent to be welded together by the purchaser. Not a prefabricated tail section that just needs to be welded onto the rear of the frame.) It isn't thin, but if the tubing is 1" instead of the stock 1 and 1/8" tubing, it flexes too much. It hasn't caused any accidents that I've heard of, but it gets a little loose in the ass when you're driving 60 or 70 mph. I'm saying I think it is a kit because I would be surprised if the "builder" who welded on those axle plates could have managed to fabricate those rails. Just my opinion (I'm totally right though.)
The main complaint is that it would have cost Black Widow or any other maker pennies more to use 1 and 1/8" x .120 tubing instead of 1" x .095. One of the reasons they did it, is that the bottom hardtail-section rails slid into the existing bottom rails, instead of having to use slugs to butt the two sections together. It looked like hell besides being weaker.
If you don't have the time and inclination to do the work, I wouldn't bother. I said it wouldn't be that hard (which it wouldn't) but it might be a little time consuming. Personally, I would secure the whole frame to make sure it couldn't move, pack the seat rails with sand, remove the welds that are tacking it to the backbone and use a piece of packed 2" pipe as a form to bend the seat rails down. Do it a little at a time and keep checking to make sure it's all square.
I used one of your pics to give an idea of what I mean:
A.) REMOVE WICKED AWESOME SEAT.
B.)...
