Denisesewa
Today I tore down the 1978 750 tracker to find the howling noise in the bottom end and found an inner main bearing toasted ( as I suspected so I have another crankshaft on hand) but I also found the head and base gaskets are thick copper which appear much thicker than the gaskets in the Athena bigbore gasket set I bought, I am worried about decreasing the squish and upping compression too much with the thinner gaskets.
I am guessing the bigbore kit is not from Mikes,( the cylinder does not have a bolt on camchain tensioner cover and is the large fin variety) at least he does not list copper head and base gaskets.
So, reuse the copper gaskets?
What bigbore kits come with copper gaskets?
Other ideas?
Any suggestions or advice would be greatly appreciated !
Other ideas?
