Mattx2
Build it, don't buy it!!
hey guys,
Ok heres the problem, i've been trying to get my XS to run smooth. To do so i corrected my timing, adjusted the valves, and checked for air leaks. After all that i started her and she ran for a bit then quickly died. So i cranked her up again, then after the engine turned over twice i heared a huge bang. After changing my underwear i looked to see what was the problem. The whole left carb blew out of the holder. So i thought maybe just a million/one change. So i shoved the carb back into the holder and cranked her again. AND THE SAME RESULT! The choke is off, the engine is barley warm and im getting the same result every time i start it! I played with the mixture thinking it was getting to much fuel, out turned out not to be the case.
Im lost, Any Ideas?
Im lost, Any Ideas?
