hello people, first time writing on a forum, ever! I have a Yamaha sx650 us custom 4G7, and am having problem getting it to tick over and sometimes even to start. any help anyone can give me would be much appreciated. firstly i am working from a Haynes Manuel and there seems to be three different types, the A, B and c, and i am unsure as to which model my bike falls under, it can make a difference to value clearance (inlet and outlet mm). if anyone can shed some light on that that would be great. i original signed up here to the site to access a pdf, with a detailed list on model info, (which aged by bike by a year and told me the 4G7). but didn't tell me which cosponsoring model i should use from the Haynes Manuel.
The main problem I'm having is that it has started but run lumpy I have set the exhaust @ .006 inch, inlet @ .002 inch checked the point setting with a strobe spot on taken the cab to bits and cleaned it, believe I have done everything that should but still have the problem of not starting or when it does it does not run for long and back fire through the cab seem like one side. It has been sitting in my garage for about 10 years under cover
any help thanks guys
Frank
Frank
