I am working on my 77 xs650, trying to get it running and have come to the point where I have ordered the next round of parts and thought I would make sure that I am not barking up the wrong tree. First I'll give you guys the information on where I am and see if I am making the right conclusions. I'm having to learn this all as I go so there is no telling where my mind pulls ideas from.
I got the bike from a friend and it had sat with gas in the tank for 2-3 years. There was rust in the tank and the carbs were seized. I pulled the tank and carbs and blasted the tank and coated it. I replaced the battery and spark plugs and air filters and tried to keep all of that as authentic as I can. I replaced the oil filters and did a good check up of everything that I have read in the manual as things that fail. I replaced the gaskets on the side covers. I am about to get the new petcocks for the tank and have just made a temporary gas box to supply fuel while I work on getting it running. I have adjusted the valves. The starter turns the motor and it acts like it wants to crank but there isn't ever any fire. Every once and a while, it will backfire through the exhaust. The first thing I thought was timing. I checked the gap on the points and the condition and they seemed good. Still no start so I went back to the carbs thinking it was something I had done. When I have the plug out and grounded I get some spark but wasn't really watching to see the timing. I can smell gas on the plugs but it isn't as strong as I'm used to from working on cars. They aren't sopping wet but definitely smell of fuel. Then again, I am in the garage and most things smell like fuel as far as I'm concerned. On a hunch, I decided to test the points to see if the timing was just way off or if there was something else I was missing. I hooked up my multimeter to the points and it looks like I am getting a charge for spark through about 80% of the rotation. It starts reading 14.3 when the F line is around 180 degrees away and stays at that voltage until about 1.5 inches after it passes. It does this on both sides. After this discovery, I tested to see what the voltage was at the plug and it tells the same story: the spark plug is charged for long enough to make the spark plug spark randomly. Now, this is all just my assumption because I don't really know how all this works, just what I read in books. I'm a machinist by trade so this is a whole new level of troubleshooting for me.
On the way here on Wednesday, I have two new points, two new ignitions, new wires, new boots, new condenser pack and new lead wires just in case they are shorting out the whole system. The advancing side looks to be in good order from what I can tell.
I guess the question through all of this garble is: Is this the appropriate train of thought or is there something else that I am missing? The bike was very well taken care of until the owner bought a new bike and let this one sit for too long. I would just like to get it running without replacing all of the parts I don't need to.
Thanks
Thanks
