All this is awesome! So, if I read the measurements correctly, so far we have the following approx measurments:
70-72, 34mm forks, uses a 174mm fork to fork on center measurement, offset is 60mm
73 - 34mm forks, 184mm fork to fork on center measurement, offset TBD
74 - 76 34mm forks, and 77+ 35mm forks, 184mm fork to fork on center measurement, 47mm offset
Does the above look good so far? Will need to get an offset for the 73 model.
I'll need to source an extra 35mm top triple to send to Cognito as mine is currently in use now but I think this will help us and them.
Thanks again guys.
I've done a bunch of measuring.
these are my late model dimensions.
CL TO CL fork tubes 184.88
offset fork tubes to stem 46.88
some of the measuring and the math (go for it 2M!)
couple shots show the caliper returns to to 0 +.01mm between measurements.
Round them off to 185mm and 47mm ?? for us old school guys rounding up .12mm = about .005"
I measured and sorted to use straight and true used original parts, tightened the clamps on the triples, set at each end of the fork tubes. Tubes were checked for straight by spinning on the lathe.
72 73 dimensions,
The measuring wasn't as rigorous on these early pieces, but I think it gives you the idea, my measuring of 70 and 71 bikes shows agreement with 2m's statement that 70-72 are the same size.
so;
10mm increase in tube cl - cl, in 73
the offset change from 60 to 47mm came with the 447 chassis in 74
then an increase in fork tube diameter from 34 to 35mm in 77
Compared the 12" digital calipers to some 1 2 3 blocks.
note caliper set to read "
So this is the short version of fitment.
rounding to nearest mm
fork tubes center to center
1970-1972 175mm
1973 on 185mm
offset fork tube center to steering stem center
1970 -1973 60mm
1974 on 47mm
fork tube diameter
1970 to 1976 34mm
1977 on 35mm
stem length grew about 1/2" in 74 also. not 100% on the year this changed.
Add to this the changes in instrument and ignition lock mounts, probably not your worry but the short version is there were a LOT of different top triples and at least 4 different lower triples used.
