MikeC23
Ok, so the bike idles great but when I give it some throttle the rpms take off. I've read through every old thread on climbing rpms I could find but couldn't find a solution to my issue. Here's what I've tried. Removed advance timing rod, cleaned it, regreased it, removed Bob weights, lubed their shafts, and installed new springs (and removed one ring from the springs so there's more tension). Sprayed started fluid around the carb boots to check for an air leak. Nothing. Using the brakes to bring the rpms down seems to work but they won't drop on their own. I've also tried swearing, sacrificing goats to the xs gods, and a little bit of crying. Any ideas?
