alfredo
1978 xs650 Special
My bike has a little trouble running. It wouldn't start on choke, idle, would race when cold and warm, would be hard to start and would kick back every so often so hard I walk funny and am officially scared of the kickstart.
After assuming most of this was caused by the carbs, that have been sitting in a ziplock bag for over a year since rebuild, I sent them to get rebuilt by another forum member. They have recently come back from getting a fresh rebuild and clean and I just put them on last night.
This weekend I hope to get it dialed in and running good. At least good enough and have it stop eating my ankle with the kick back.
Now, on to the actual questions;
1) I have heard the kickback could be that the cam gear is off a tooth or two. I am pretty sure this was all good and have pictures that look like it all is good, but I am never 100% on anything . Can I take the head off and check with the bike in the frame? I have only done internal work while the engine was in the stand.
2) Could the timing and bad carbs just be the cause of kickback?
3) When I had the bike running before I set the boyer timing to full advance and had the white paint mark on the magnet in the hole. Looked great and I could get it running after a while of tweaking with the carbs. When I put a light on it to check the timing it was from 1/4 to 1/2 of the way back towards the TDC mark. I read almost all the docs and can't find what the RPMs should be to set it and if I should be setting it back to the full advance mark or the TDC mark?? Seems like the marker was so far back when it was close to idle that turning the plate to get it back to the full advance mark would be a huge change. I am used to timing cars and the difference is usually very slight so I am applying similar logic to this, but could be wrong.
4) I know I mentioned it already, but the kick back . . . . damn the kick back. Make it stop!!! Please!!!!! I am almost to the point of rethinking the wiring and setup so I can fit was of those cinder block batteries for the installation of a starter. So, that wasn't really a question, but just wanted to express my fear and loathing of the kick back this baby produces. Funny thing is, my friends and family can kick it for twenty minutes to get it to start . . . . no kick back. I try once and it makes me limp for a week. It knows . . . .
So I guess that's it for now. Just really anxious to get this thing starting and driving reliably. Any help is appreciated guys!
