G'day,
I just received this in the mail
http://www.dimecitycycles.com/vinta...tch-headlight-blinker-kill-horn-12-0041b.html
and I'd read they listed a function as "Headlight Passing/Kill - Yes" but now that I have it in my hand I'm not sure how they set the passing button to run the kill switch.
Wiring code for the switch is as follows:
yellow - low beam
black - horn ground
brown - left signal
green - high beam
brown/white - t/s main wiree
red - h/l main wire
blue - hi beam led ground
pink - horn main wire
dk green - right signal
I'd have thought that the pass button would link power to the green wire so unless I can pull the switch apart and have the wiring re-done but then I'm not certain how that'd need to be wired.
Any tips on this? Thanks.
yellow - low beam
black - horn ground
brown - left signal
green - high beam
red - h/l main wire
