MrBillohnooo
I did a search, and found a link, link no worky. I have a 77 model. trying to simplify the wiring without starting from scratch till winter.
Thanks!
Thanks!
Have tried that...does not seem to work on my 1977....jumpered out the safety relay...which worked for a little while...it's all very weird. Put everything back to the way it was ...no headlight...everything else is working perfectly...and yes the headlight bulb is good...anyone got any ideas???...ideally I'd like to get rid of both relays and I'll take my chances with the starter engaging accidentally.
I removed mine because there was no way to know if it itself fails safe.
Something cool you can do while you're there is re-purpose the indicator light as a generator failed light. Pamco Pete's idea I think. It's like an igntion light and comes on when you turn the key on (generator isn't working yet) and goes out when the engine starts, and stays out unless there's a generator problem. Very easy to do, just reroute a wire back in that same general area.
can anyone clarify this... seemed a little vague.
I am assuming a wire from the indicator light to the generator? A specific location? Couldnt seem to find anything in the archives.
