How many rear sprocket teeth for wide tire
BobbedSled
Wilmington DE & Boca Raton Fl.
Stock motor no big bore or long rod super cammed race fuel deal. Just a plan old stock motor.
Gearing multiplies torque so going up in the rear should work well at the expense of cruising speed, but as a bar hopper/fun bike that is an acceptable tradeoff. I can go down in the front too I know but I prefer to go up in the rear for aesthetic reasons.
Will be running a 240 Avon tire. I am speculating that I will need to jump from a 34 rear tooth count to a 38 tooth count. That sound right size wise given the tire load compared to stock? 240 is a pretty big girl.
Thanks!
That's a LOT of rotating mass to pull with a stock motor. If I were trying that out, I'd probably get the largest rear sprocket available and a suitably long chain with several spare master links. Might take a good bit of tinkering to get it happy.
Right, I have 2 chains actually as I am running a jack shaft. I am starting with a 38 tooth sprocket.
Sprockets have to be custom made, thus largest rear sprocket available is somewhere around 75 or so. No way it need to be that large.
I will have to go a look.
not wide it is a 18" wheel probably around 4" wide
the bike was a tracker when I got it.
so top end was not what the PO was looking for
