Hugh’s hand built timing
Efields
XS650 New Member
Texas
Scratching my head here, I’ve got an xs650 with a Hugh’s cdi ignition the previous owner put on. It seems like the timing is a bit too advanced, how exactly do I retard the timing on this setup. Every thread just explains finding tdc with the damn sticker. Nothing about actually adjusting the timing
Thanks in advance <— pun intended
You either move the pickup, or you move the rotor relative to the crankshaft. If there is a weoodruff key, it should be possible to get keys with some offset. It may even be possible to delay timing by wiring a capacitor in parallel with the trigger wiring. But that is a case for the electronic gurus her to expand on.
