BobberNick
I'm looking for the Following items for trade or purchase:
-The spring on the end of the rear brake light sensor
-one bottom rubber riser mount and washer for a later model riser
-nuts, bolts and acorn nuts all sizes
-Headlight stays
-inexpensive axle mount taillight and lic. plate combo
-clutch and throttle cables for drag bars.
-new or well maintained drive chain (I'll have to count teeth on my rear sprocket
-Front axle spacer. I have my speedo drive mounted, but on the opp. Disc brake side there is a small gap between forks and hub.
-exhaust stud where headed mounts for a '77 "D" model motor.
-Dummy oil tank for electronics
-Ignitition with keys and any parts associated with the ignition for that "D" motor
-Headlight stays
