ID Frame help
spacejockey4
Tx
Hello,
Anyone know what frame this is? I'm trying to figure out what motor mounts I'll need. No angles or dimensions are stock and the neck is raked. Thanks!
Unless someone sells 'em, you'll need to make your own. Pretty sure that's a Harley frame. I'm also pretty sure no one makes an "off the shelf" kit to put an XS motor in a Harley frame.
'Course I might be off in left field... :umm:
The frame appears to have had a XS650 in it. The front and lower (center) mounts look like XS650. Just set your 650 in it and see if it fits. Might have started as a HD frame but HD motors don`t mount like that.
You're correct, it was sold to me as a frame ready for an xs650 motor. I have another xs650 with the original frame and the mounting locations are in the right place, so i was hoping mounts existed somewhere vs having to fabricate as Jim mentioned above.
