Junkyard Johnny
I have a 75 that I just did the top end this spring. Also put in a pamco and a dual output coil from mikes. Shes been running like a charm until a couple weeks ago. I got it up to highway speed and temp then ran er home and when I got into the driveway, I sat and let it idle for a few seconds and it dies. Doesnt stumble or cough. Dies like I shut it off by switch. As I rode it the following week, it would die more frequently at stop signs. Then it started dying as I revved it at takeoff. Now its almost unrideable. It'll start but will only run for about 10-15 seconds and die. I always shut it off then fire it back up and it starts again every time. I was running non resistor plugs and non resistor caps. I put in a set of iridium plugs I had sittn because they're resistor plugs and it ran and idled longer. About a minute and a half. But it did die again. My question is, is my coil slowly frying or is it possible that not running a resistor toasted something on the pamco? The transistor? All my wiring looks good. Thanks in advance for any help.
