Purplezinger
Early 650's have some of the weakest ignition coils ever manufactured. They really didn't improved much until the TCI models. If you have a points ignition with factory coils you will have problems adjusting the carbs. You will have idle, midrange and high speed problems that appear to be carburettor issues. It's not, it's the coils. That said, back in the day, the hot trick ignition setup was 2 K-Mart brand,
non resistor, 12 Volt coils for a Chevy pickup. You also used a single ceramic ignition resistor and 2 GM ignition condensers. The one and only down side was size, the Chevy coils will not fit the stock location.
Most installations had the coils hose clamped to the front down tubes. Some were hidden under the seat. All of the ones I did were mounded on the down tubes. I don't see this mod anymore but it is still an excellent choice for a points ignition on a budget. As they say "You go from a wet match to God's own lightning".
